View Full Version : konica 7020 F35-8
ck1
09-25-2008, 09:21 AM
i know this code is fixing error code , but i check the lamp ,thermostat is ok and try to reset with Dip swicth 25-3 to 0 .but still error code . please help thanks ;)
kmcopytech
09-25-2008, 10:49 AM
25-3 to 0 reset ????
reset trouble the right way:
25 MODE,
DIPs switch 3-1 to 0...
Haroldbfix
09-26-2008, 05:20 AM
25 MODE,
Replace temp sensors which is a common issue with that model series, Of course that's after you reset the code. I would print out a failure list to see if the machine has a history of the code, then make a judgment call on the sensors.
ck1
09-26-2008, 07:05 AM
oh... 7020 difference with 7145 ??? :confused:
DCPS
09-26-2008, 04:24 PM
I would also check the power supply if you have the coorect voltage on the lamps (Europe 220VAC, USA 110VAC).
