View Full Version : Bizhub 950
antone
07-18-2018, 05:51 PM
All trays all sizes...when feeding the short edge direction.......the First 3 to 4 inches is wavy coming out. LONG EDGE IS FINE
Sent from my SM-N950U using Tapatalk
Synthohol
07-18-2018, 09:25 PM
If you remove the finisher does it still warp the paper on exit if so probably during the turnover after it leaves the fuser if it's straight have an issue in the finisher.
Could also be a short grain vs long grain paper issue and humidity.
Make sure the rollers under the adu are super clean of all dirt and toner.
You can also try printing face up to eliminate the turnover area as the cause.
antone
07-19-2018, 12:52 AM
I did remove finisher..
Same thang!
blackcat4866
07-19-2018, 12:58 AM
Did you look at the curl adjust? =^..^=
Synthohol
07-19-2018, 01:36 AM
try face-up copies (in finishing choose face-up)
this eliminates the turnover process and comes straight out.
if waves are still there check the exit roller one way gear. it may be slipping a bit and as the fuser is pushing it out if the exit roller is slow that may be where the collision starts and causing wavey paper.
