View Full Version : [PHOTO] Magenta and cyan vertical lines on first copy KONIKA MINOLTA C220
Copycrazy
09-06-2018, 09:44 PM
Hi
I have buy a 60 000 copies Minolta bizhub c220
I have this problem, when i print a photo, first copy has vertical lines (oposite feed direction) magenta and cyan. After 2 or 3 copies the lines disappear.
Toner levels are high, image units are good 60% used.
Here an image, printed on recycled 220 gr cardboard. I have tried to print this cardboard on other minolta machines without problem.
40561
How can i fix this? It's a bit annoying that strange issue.
Best regards
Toxic
09-06-2018, 11:04 PM
What is distance betwen 2 magenta lines?
If it is about 96mm it is drums memory problem,maybe someone exposed drum to sunlight,etc...
Copycrazy
09-07-2018, 09:42 AM
Hi, yes, distance betwen same color lines is about 90- 92 mm
The annoying is that only happens on firt and second copy gradually.
Sure this can be a light exposure image unit? Its strange that happen only with two colours.
Best regards.
Toxic
09-07-2018, 10:00 AM
Is it occur on all paper types and weights?
Toners are original OEM or replacement?
Copycrazy
09-07-2018, 01:29 PM
Hi, toners are original minolta, it happens on all papers, i have just test it.
Albonline
09-07-2018, 03:33 PM
try cleaning the charge grids and pre condition/neutralizer leds,but think you will end up having to replace the drums.
copier tech
09-07-2018, 04:36 PM
Post better samples, the gradation prints in CE mode will show each individual cololur making the issue much easier to diganose.
Copycrazy
09-07-2018, 05:39 PM
Hi
I attach new high res image of first, second and third time prints of the morning try for a customer order. Until tomorrow can test gradation print because the machine is being used and doen't show the issue. At least must be 4 hours stopped.
Always 192 mm between lines.
40576
Copycrazy
09-07-2018, 07:16 PM
Hi, thanks for the response, some tutorial about how to do? I suppose all the parts are built in image unit set
I'm a bit new but with little help can fix, i'm used to disassemble electronics.
Copycrazy
09-09-2018, 11:35 AM
I have do a new test print , i have rotated the cyan drum by hand before the print.
As result , the cyan lines have changed its position.
I will try to clean charge grids and pre condition/neutralizer leds but want to be sure of the cause before do this.
this is turning on a headache for me
Phil B.
09-09-2018, 12:51 PM
well the symptoms have changed on the same color... there is your answer... change the PCU
