View Full Version : CQ Konicaminolta C258 washed out prints
Bula
10-02-2018, 09:28 PM
Have a weird issue internal print out of demo/config/and font pages being very feint and lacking solidity.
Other internal prints are fine eg.management lists,counter prints etc.
parts replaced, laser unit/mfpb/hdd/eeprom
Any Ideas
Synthohol
10-02-2018, 11:02 PM
have you ran gradations?
Bula
10-02-2018, 11:48 PM
yep done that
thanks
Woxner
10-03-2018, 12:44 AM
why care about a demo page. use service mode to test for quility. i have seen this but left it alone because it does not affect customer. dont waste money and time
Bula
10-03-2018, 03:00 AM
money and time has nothing to do with it. I'm looking for answers
Synthohol
10-03-2018, 01:21 PM
run the gradation and halftone test prints in service mode, if they look ok then its just the pattern file.
i have noticed the demo pages do look kinda flat on the new series.
may be nothing to be concerned over.
scan the demo page and post it, i can tell you if it looks like what i see in the field as well.
Bula
10-04-2018, 04:54 AM
Hi synthohol Attached is 2 prints good & bad
Synthohol
10-04-2018, 05:06 AM
i would try backing up the machine to USB and performing a network data clear under initialization then restore if necessary.
almost like something in the code that doesnt use the right density.
i saw nothing in the knowledgebase about this.
UKTeam
10-04-2018, 12:53 PM
Hi Bula,
I will assume COPY is OK?
And the good sample is from another MFP.
It seems obvious, maybe too obvious.
If everything Printed WITHIN Service Mode is good, and everything Printed OUTSIDE of service mode is weak, surely this means someone has enabled Toner saving Mode.
When you replaced Main motherboard all previous settings would have been restored.
A full data clear would get rid of it, but check this first....
Utility - User setting - Printer Setting - BASIC Setting - Pg.2, Toner Saving Mode....
In a way, I hope I'm wrong after all your effort changing bits...!
Mark
Cantechman
10-04-2018, 06:10 PM
Any Ideas
I have the exact same issue on 2 c308's installed at the same time in the same location. I didn't replace any parts though as test prints in service mode and all print and copy jobs are fine. I just left it as is and the machines have worked fine otherwise for the past 2 years.
Bula
10-04-2018, 08:46 PM
Hooray To Mark and not forgetting all other inputs from the rest
Thanks guys
Issue found in user mode as placed by Mark
