View Full Version : Inceppamento duplex 364e
Natale65
11-14-2018, 01:02 PM
salve sono un tecnico ma in 31 anni di esperienza non mi mai capitato un difetto cosi
all'accensione la macchina inceppa il primo foglio in duplex sia in stampa che copia poi i successivi funziona perfettamente per tutto il giorno se spegni la macchina riaccendi e nuovamente si blocca
da un prima verifica si vede che il foglio non convoglia nel duplex ma esce sulla guida fs533 ovviamente si blocca poi dopo riprende bene
a voi suggerimenti:confuso::confuso:
Bix
11-14-2018, 04:07 PM
It will seem absurd but I solved by disassembling and reassembling the FS-533 :D
Natale65
11-14-2018, 04:26 PM
the problem does so even without FS 533I had also tried this
blackcat4866
11-14-2018, 11:51 PM
Google Translate:
hi I'm a technician but in 31 years of experience I've never had a flaw like that
when the machine is switched on, the machine jams the first sheet in duplex both in print and then in subsequent copies it works perfectly all day if you turn off the machine and switch it on again.
from an initial check we see that the sheet does not convey in the duplex but exits on the guide fs533 obviously it locks up then after it resumes well
to you suggestions: confused :: confused:
Phil B.
11-15-2018, 04:21 PM
what really confuses me is:
no mention of WHAT has been done!
did you check sensor operation in SM?
did you CLEAN the internals?
what is page count on parts?
current firmware?
