View Full Version : Konica Bizhub C458 Jam Duplex
Sheshonq
11-20-2018, 07:31 AM
I have random problems with duplex jams: 93-10, 32-01, 32-05, 30-03. Any idea ?
Sheshonq
11-20-2018, 07:45 AM
41102
I checked the solenoid motor.
Sheshonq
11-20-2018, 07:53 AM
41103
Sheshonq
11-22-2018, 06:07 AM
41111
It continues...
Sheshonq
11-22-2018, 06:08 AM
41112
Sheshonq
11-22-2018, 06:10 AM
Temp. & Humidity :
41113
It happens when the printer has only 130,000 copies. :confused:
Norwaytech
12-12-2018, 10:32 AM
I got a C458 . jamode 9310 ( a lot of them, some 9202 and 3003. the coper has only 16000 printsand 100 james in total
I swapped over the hole unit in page 48 in the parts guidemanual - possibly problems with the stepper motor A2X0M10600 (M5) or one of the Photointerrupter.
allan
12-12-2018, 03:51 PM
There is a weak plastic bushing on the front of the switchback unit causing a belt to skip. Normally some noise from the exit section.
If that is the case modify by installing a brass bushing. Some drilling and some glue involved.
Sheshonq
03-26-2019, 09:42 PM
Do you mean i have to replace plastic bushing by brass bushing ? Where do i have to drill ? i don't understand. The glue, what for ?
DK-tech
02-03-2022, 01:42 PM
I just had 93-10 on a C558. I adjusted the right door so it tilted counter clockwise. Seems like it did the trick.
