View Full Version : Error Code C6500- C2840
kenpio
01-08-2019, 09:46 PM
I have a C6500, an oldie but goodie, customer does not want to part with it, they don't have a contract. Started of with a C-2804. Quoted the customer for a black developer unit and developer, the quote was over $1000, they said yes. Ordered DV unit, had DV in stock. Went there today and changed the the K DV. It added fine and did the initial toner adjust and did fine. I went to do the Gamma adjust and I came up with a C-2840. Took out the color registration sensor and cleaned them off. Still am getting C2840, Book says it is the PS11 sensor, I know it would be better to replace the assy. Would this be a good call??
KEN
tulintron
01-14-2019, 05:41 PM
KENPerfect!
C2840 indicates an error in the calibration of the gamma sensor.
if you disable the sensor, the machine operates normally.
you gain time and replace the sensor soon.
tulintron
01-14-2019, 05:42 PM
KENmake tests and be sure to be printing the 04 colors without fail.
blackcat4866
01-15-2019, 01:21 AM
Also, manually check the operation of the shutter. If the shutter does not open far enough you can also get this code intermittently. A little re-forming can get you more travel from the shutter mechanism. =^..^=
princef18
01-17-2019, 10:08 AM
I used to face this issue a lot on the field.
I would force the shutters open by taping them up temporarily. Buys you some time to get the parts.
kenpio
01-17-2019, 09:49 PM
I did open and close the shutters and they did work. Through the I/O. I will disable the gamma adjustment and see what happens. This customer just wants it to run. Right now, all the drums, coronas and transfer belt are all over 125%!!!
KEN
blackcat4866
01-17-2019, 10:54 PM
KEN
If you care about your image quality at all you'll pay attention to those yields. In my experience corona units never make 100%, closer to 50% before image quality necessitates changing. Drums and developers will do the full yield usually. Don't let the primary transfer cleaner go past yield, it will make a huge mess, including your C2840's. Fusers can sometimes go 1M or a little longer. =^..^=
princef18
01-18-2019, 07:45 AM
KEN
Hi Ken,
Recommend the customer to atleast change the developer. Regarding the shutters, i would advise to tape them open first to isolate it. Possibly the shutters are not opening all the way.
kenpio
01-20-2019, 08:43 PM
Put a piece of tape on the shutter, and still came up with the C2840. So I shut off the image stabilization and it came up and it making prints. I will try to attach the screen shot of the consumables. So I told the customer that I could not guarantee the print quality with out replacing all these parts. Well I cant upload this, so the drums are at 157% and black at 171%, developers are at 117% and the coronas are at 155% and the black at 171%. So I think that this has a little to do with this problem. I will include the transfer belt job too.
KEN
41480
blackcat4866
01-20-2019, 08:46 PM
Perfect. Good luck getting them to shell out the money for all those parts. =^..^=
kenpio
01-21-2019, 10:09 PM
Gave a quote about $3500.00, found out that the coronas for this are no longer available. Would the coronas for the C7000 work on this? Don't think they will go for it though. I got the salesman after them. :)
KEN
