methogod
01-15-2019, 11:13 PM
Always USE OEM everything - DRUMs are DU-104....
Black drum keeps failing early with memory type failure. 3 in a row.
Can put the K drum into another color and sometimes get some more life (or hide the issue for a bit) but once they fail they fail.
Never had them go in just one color like this... HV may be suspect.
Today, Did a PM which was due and replaced black HV unit... machine has 2.6m anything you guys see that makes you think something is off elsewhere?
We now replace coronas at 50-60% life as we print 12x18 mostly (print shop).
Here is the adjustment list. Let me know if you need any more info
https://www.dropbox.com/s/p25m4r8v70s4dkd/SKMBT_C45119011517150.pdf?dl=0
