PsYcH
02-21-2019, 04:22 PM
Hello, so I have a problem on my minolta C220. One day it started to make some noise, sometimes noise dissapeared, sometimes appeared. For now, it is very noisy, and I found the problem for this, it`s one of the gears in transfer belt. Looks like it doesn`t have enough tension to gear below it. Actually cant understand, why this happens and which part needs to be changed. Belt by itself? Adding video to be more clear.
https://vimeo.com/user49447170/review/318804656/b8344edf4b
As you can see, I`ve added some paper to make some tension down, then noise dissapears, when i remove it, noise appears again.
