View Full Version : Bizhub 1050
oakblue
10-05-2008, 11:08 PM
Does anyone know if it I can print to a 1050 without the touchscreen contol panel?
big jase
10-06-2008, 03:38 PM
you will be able to print,only problem i can see is setting up ip address on machine,with no display to follow
ni311
10-06-2008, 03:39 PM
Another problem will be when you'll setup the paper type in different trays...
Itsthepaper
10-08-2008, 03:47 AM
There is a way to see the control panel on your computer and activate eveybutton as if your in front of the machine. I remember this from class i have never tried it.
oakblue
10-08-2008, 11:22 PM
is there special konica software I need to do this??
mtp23451
01-04-2011, 02:31 PM
What is the way ???
Hemlock
01-04-2011, 02:43 PM
If I recall correctly, there were 2 ethernet ports on the back/side of the 1050, one for printing/scanning and the other for Web Utilities, PS JobEditor, NetBackupTool and Mail remote notification system. They required 2 different IP addresses and, if configured, pointing a browser to the IP for teh web utility port/addy would allow control of a virtual touchscreen. You could make all your setting selections for paper and such, you just couldn't make it print/copy like this.
Once paper settings are done, you should be able to send a job; just make sure it's set to release/print automatically and not go to a hold queue.
It's been several years since I've touched one of these, so take this with a grain of salt.
redhotrob
01-06-2011, 01:08 AM
You can use the machine nic, register your IP into the machine, then use remote panel.
Hemlock
01-06-2011, 05:34 PM
Without a touch panel, is there any way to configure the NIC?
RRodgers
01-06-2011, 06:57 PM
Yep, what he said.
AVux07
02-09-2011, 10:09 PM
How do I "register your IP into the machine" cause I'm getting a message to "Register Authorized PC's before using Machine Manager setting" when I try to edit user passwords on web utilities on a BH950, though I can get to the WU screen fine.
MADSYS
03-07-2011, 10:48 PM
Prior to use Remote Panel the machine administrator should register those PCs accessing through Remote Panel. Please review the POD Administrator's Reference User's Guide which you could download from Support | Konica Minolta Business Solutions, U.S.A., Inc. (http://kmbs.konicaminolta.us/content/support/supportmanuals.html)
Good luck
