View Full Version : Minolta C3102
digicor
10-20-2008, 04:47 PM
How do I re set the fuser and transport roller unit to trip the machibne so i can re use the units? I have been told this can be done to get a second use out of them.
THanks;)
10871087
10-20-2008, 04:55 PM
the units are fused. I forget what size they are.
jjw23
10-20-2008, 07:21 PM
yes there is a fuse on both of them you need to replace. On the fuser you have to take it apart carefully to get to the fuse which is covered by black tape. Then the transfer belt has a small bulb fuse that is behind a small panel, very easy to find.
digicor
10-20-2008, 08:38 PM
what size is the fuse? I found it , is it the 1/8 pico fuse i use in my rebuilds for the dI rebuilds?:confused:
jjw23
10-20-2008, 08:51 PM
i use the 1/16 green fuse from newark sku 12J4187
digicor
10-20-2008, 09:01 PM
thank you
i appreaciate the help.
jjw23
10-20-2008, 09:08 PM
oh and make sure to soder it on, so it has a good connection.
