dqydj
10-11-2006, 11:23 PM
This code is a hardware time-out.
What I've got going on is when I go into service mode
and then state conformation and run a check on the memory
the work memory checks fine but the two file memory sticks test bad.
I've replaced the file memory sticks and I still get the same thing.
I've flashed the machine but still codes out.
Any one seen this? I figure it's a board problem but which one?
If you've worked on these you know the mfp unit on this thing is a
series of individual boards all connected together.
I appreciate any help on this one.
