View Full Version : konicaminolta bizhubc450
maks
12-22-2008, 03:13 PM
can someone pls.tell me what does C-3201 eror code is...salamat
RayC3
12-22-2008, 07:08 PM
Looks like C-3201 indicates the Fuser drive motor is not turning.
maks
12-23-2008, 02:42 PM
thanks for answering RAYC3
Benedict
01-05-2009, 10:39 AM
442
Troubleshooting bizhub C351/C450
16.6.45 C3201: Fusing Drive Motor’s failure to turn
16.6.46 C3202: Fusing Drive Motor turning at abnormal timing
16.6.47 C3301: Fusing Cooling Fan Motor /1’s failure to turn
Relevant Electrical Parts
Fusing Drive Motor (M2) Control Board (PWB-MC)
Step Action
WIRING DIAGRAM
Control Signal
Location (Electrical
Component)
1
Check the M2 connector for proper connection
and correct as necessary.
2
Check the Fusing Unit drive for possible
overload and correct as necessary.
3
Check the PWB-MC connector for proper
connection and correct as necessary.
PWB-MC PJ2MC-5 (DC24 V) H-2
4
M2 operation check PWB-MC PJ31MC-10 (REM)
PWB-MC PJ31MC-13 (LOCK)
C to D-17
5 Change PWB-MC — —
Step Action
WIRING DIAGRAM
Control Signal
Component)
1
C to D-17
2 Change PWB-MC — —
Fusing Cooling Fan Motor/1 (M9) DC Power Supply (PU1)
Step Action
WIRING DIAGRAM
Control Signal
Component)
1
Check the connector of motor for proper
2
Check the fan for possible overload and
3
M9 operation check PWB-MC PJ6MC-4 (REM)
PWB-MC PJ6MC-6 (LOCK)
K-9
4 Change PU-1 —
Hope this will help you good luck.
lagustacat
07-01-2015, 12:23 AM
Getting C3301 Error does this mean faulty cooling fan, do I need to replace this
442
Step Action
WIRING DIAGRAM
Control Signal
Component)
1
2
3
4
C to D-17
5 Change PWB-MC — —
Step Action
WIRING DIAGRAM
Control Signal
Component)
1
C to D-17
2 Change PWB-MC — —
Step Action
WIRING DIAGRAM
Control Signal
Component)
1
2
3
K-9
4 Change PU-1 —
