View Full Version : BizHub 200/250/350 CN1000 Special Vend
pepper38_cnd
01-04-2009, 01:47 PM
Does anyone have any information about the pin out or wire harness available for CN1000 on the main board. It is referred to on the SSD but I cannot find any of the information. I am told this connector will let you connect an intelligent vending device. We are trying to connect, card readers, the ones we have ( supplied by the customer ) do not work well when connected via the key controller connector.
Benedict
01-05-2009, 09:02 AM
Field Service Ver. 2.5 Jul. 2006 12. Counters
205
Adjustment / Setting bizhub 200/250/350
12.3.4 Copy Kit
12.3.5 Plug-In Counter
<Count Table for the Plug-In Counter>
12.3.6 Key Counter
12.3.7 Vendor Mode
Functions
• To enter a value for the Copy Kit Counter.
Use
Setting/
Procedure
• When the current value reaches the set value, the following appears.
• Mode 2: The icon appears in the Additional Message Display.
• Mode 3: The maintenance call reminder “M4” appears and copying is prohibited.
• Press the Clear key to clear the set value.
• Use the Keypad to type in the set value.
Functions
• To select the counting method.
Use
Setting/
Procedure
• The default setting is “No. of Prints”.
“No. of Prints” Copy Cycle
• No. of Prints: The count increments according to the number of pages that is outputted.
• Copy Cycle: The count increments according to the number of copies.
Copy Mode For 1-sided copies For 2-sided copies
Setting
Large Size Counter
Non-standard
size
Standard size
Non-standard
size
Standard size
Total Counter
Mode Mode Mode Mode
1 2 3 1 2 3 1 2 3 1 2 3
Count
With “No. of Prints”
selected
1 1 2 2 1 2 2 1 4 4
With “Copy Cycle” selected 1 1 2 2 2 2 4 4
Functions
• To select whether to enable or disable the Key Counter.
Use
Setting/
Procedure
• The default setting is “OFF”.
Yes “OFF”
• If the Key Counter is installed, select “Yes”.
Functions
• When the Key Counter, Coin Vendor or Data Controller is installed, select the appropriate
option.
Use • To select the mounted option.
Setting/
Procedure
“OFF” Coin Card
Reckon you would have to get KM data controller but perhaps you could change the vendor mode perhaps it works.Please let if know if it works.
Benedict
01-05-2009, 09:09 AM
205
12.3.4 Copy Kit
12.3.6 Key Counter
12.3.7 Vendor Mode
Functions
Use
Setting/
Procedure
Functions
Use
Setting/
Procedure
Setting
Large Size Counter
Non-standard
size
Standard size
Non-standard
size
Standard size
Total Counter
Mode Mode Mode Mode
Count
selected
1 1 2 2 1 2 2 1 4 4
Functions
Use
Setting/
Procedure
Yes “OFF”
Functions
option.
Setting/
Procedure
“OFF” Coin Card
pepper38_cnd
01-05-2009, 11:17 AM
Thank you I have all that information, What I am looking for specific is the pin outs and part number for a harness that is supposed to connect to CN1000 on the main board the connector is labled Special Vend.
Benedict
01-07-2009, 08:56 AM
Sorry cannot help with that now had a look at info I have will post the question to our support guys at head office but I will suggest you contact your supplier as the card reader systems are usually designed by electronic companies who usually just require a point to point diagram to design a system which will work for your machine.Unfortunately I have not had to connect a card reader to the Biz 250 range yet but if you come right please let me know so that I can archive the solution. sweeet.
