kbushnz
02-02-2009, 08:52 PM
Hi All
Trying to get my 7035 hooked into my home network (peer to peer)
Unit was used. So reset IP-421 card per service manual.
Connected to DSL-G604T router. Initially was assigned an IP address from router (10.1.1.5) and I was able to use the WEB interface to get into the menu. (confirmed by status printout after 7035 unit power up)
Can view and edit via web interface.
I have trolled the forum for similar issues but this one has me stuck.
I have set it up via windows XP with the Add printer, local printer, config TCIP port etc etc.
Set Port number at 10000 to match ip-421.
But windows doesn't seem to see the printer.
and any jobs sent to printer just fail. (naturally)
I have noticed in my router that the DHCP clients shows my pc and others on the network but not the 7035.... It did once but doesn't show anymore.
Could this be the issue...
Note as per my previous thread I have used it with straight parallel port connection with GDI drivers.
Any help would be appreciated.
Calvin Tyler
NZ
Calvin Tyler
NZ
