View Full Version : 6500 v 6501 Toner?
mnorris13
03-05-2009, 09:43 PM
Is there a difference in the toners? Can i use 6500 toner in a 6501?
Juggy
03-07-2009, 06:04 PM
No both machine uses different toner. C6501 use
TOner type Part number
TN612 BLACK A0VW150 TN612 YELLOW A0VW250 TN612 MAGENTA A0VW350 TN612 CYAN A0VW450
kmcopier
03-07-2009, 07:11 PM
Yes you can used it, the C6501 is the same only the
amount is bigger in the bottle.
StormyKnight
03-11-2009, 02:16 AM
So one would assume that the reverse would also be OK?
i.e. 6501 toner in a 6500?
If so , might have to investigate the cost per gram (ounce)
Cheers
mnorris13
03-28-2009, 03:41 PM
The only thing that needs to be done is cut one nip off the 6500 toner bottle so it keys into the machine. Other than that the difference is nothing. 6501 is completely awesome from color to everything else fixed from the 6500.
HORSE
04-08-2009, 06:33 AM
I have noticed a difference in skew between both machines, anyone else noticed this.
mnorris13
04-08-2009, 02:45 PM
We have only noticed skew on some stocks typically Junk 100# 12x18 Gloss cover. Other than that all other sizes and weights are dead on. We eliminated the skew on 100# by going to 13.6 x 19.2 paper size. No place for the paper to go but straight.
Setright
04-08-2009, 08:14 PM
mnorris! Nice solution :D
May I copy....
mnorris13
04-08-2009, 08:22 PM
May I copy....
Absolutely!
Kenny
10-24-2011, 02:18 PM
Hi does the 6501 fit straight in the 6500 then with no mods ?
thanks
Kenny
BVulgaris
01-16-2013, 12:26 AM
i have a question about those plastic nibs....
which model needs you to snip the nibs off?
from what i'm getting is
c6501 - no nibs
c6500 - nibs?
this is worrying because one 6501 model takes toner bottles with these nibs, and the other model we have does not (also a 6501 however).
Also, from what I understand. The C6501 has a skew tolerance of 1mm FTB. the C6500 claimed one of around 2-4mm FTB. Much improved on the c6501. I continually hear the c6500 referred to as a copier class machine rather than a digital press which i find interesting (other technicians i work with).
chriseckeard
04-12-2013, 09:10 AM
TN-612 has three tabs and the TN-610 has two. The TN-612 will run in the bizhup PRO C6500 (http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=c6500) but you need to cut of the middle tab of the three. 20331
Both have the same grams of toner as listed on the box. 20330
I just ran a full CMYK set of the TN-612 in my C6500 (http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=c6500). Supposedly the C6501 has a higher yield per toner then the C6500 so I wanted to determine if it would also work on the C6500.
On the same job I was able to get ~40K out of the black with the TN-610 but only ~35K with the TN-612. The color production is equivalent using the TN-612 over the TN-610 though I think the
TN-612 was 5-10% lighter which could probably be improved with an adjustment.
I needed to increase my yield by 22% to make it worth spending the extra money on the TN-612 over the Tn-610. My results proved that it was better to stick with the less expensive TN-610 Toner.
FYI- I do run the DU-104 Drums which are intended for the C6501 in my C6500. They have a replacement interval of 300K rather then the 200K of the DU-102 drums and ~ the same in price.
Kenny
04-12-2013, 10:02 AM
great post chriseckeard !
I have just been offered some CPP650 ikon toner which i believe is the same too , any experience ? It is a fair bit cheaper than the konica
I will try it on one of our machines in the next couple of weeks
ineo+6501
04-12-2013, 12:27 PM
I have a customer running the Ikon toner in a C6500 with no issues at all. £23 (Ikon) a bottle versus £40 (KM) a bottle is a no brainer.
Kenny
04-12-2013, 01:30 PM
or £8 as i have paid ! :-) sounds promising ......
regards
Dave
ineo+6501
04-12-2013, 02:16 PM
Wow that's daylight robbery.
My customer has gone through 20-30 bottles at least with no negatives to speak of.
Kenny
04-12-2013, 02:22 PM
I had to buy over 200 boxes but we will use them lol
are you a Develop dealer Ineo 6501 ?
regards
Dave
ineo+6501
04-12-2013, 02:39 PM
Yes, based in Newcastle.
Kenny
04-12-2013, 02:45 PM
Handy to know we are in Leeds we deal with Dsales too
ineo+6501
04-12-2013, 02:55 PM
Dealer or end user?
Kenny
04-12-2013, 03:03 PM
Dealer mate
chriseckeard
04-12-2013, 04:10 PM
Kenny, I have no experience with the CPP650 ikon Toner. Please share if you discover that it works or if it dosen't.
ineo+6501
04-15-2013, 09:09 AM
Did you read the previous posts? It does work without problems.
