View Full Version : Muratec mfx 1700 driver install
james
03-16-2009, 03:12 PM
I have loaded drivers but won't print. I can ping it. Is there a special port or something? I only work on Konica usually, but...
copytechman
03-16-2009, 04:54 PM
Yes it is special depending on the type, usually a special ob_ip port, it wont work with a standard tcp/ip port usually.
A.
james
03-17-2009, 01:51 PM
Thanks for the reply.
Could you walk me through? I am only a tech, not very good with ip stuff. I set up the driver for tcp/ip, raw, port 9100, snmp enabled. I can ping the printer address, but no print. Thanks for your help, I have a customer screaming.
