View Full Version : Problems with a sharp AR 5316 With strips
Harry
03-30-2009, 08:56 PM
Worked on 5316 last day with clear band 2 3 times on an A4 copy changed Drum and it simes like good after a view days same thing does anybody know wath it is?checked also for broken tears and gears nothing found ad else please help Thanks alot
blackcat4866
03-30-2009, 11:28 PM
You might take a look at the developing drive. Gears ground down or spun on a "D" shaft, or maybe a seizing developing cylinder. =^..^=
Harry
03-31-2009, 06:44 AM
The Circoferenze is from Drum and i changed it and it works fine four a couple days.My question can it be a thermical problem? Fans not Work It looks like the Developerbrush alterate the surface of the drum.
Thank you for respons!
semaj
03-31-2009, 06:56 AM
fix the cleaning blade of your Drum bro..or the opc drum may have a scratches along its side (white )..put remedy on it.
Harry
03-31-2009, 09:04 AM
There is no scratch on the Drum and the cleaning blade works fine also
Please find other solutions Thanks at all
petrus
04-02-2009, 11:28 AM
try change the transfer charger.it could be sometime.
are you sure there are no spoilt of all the drive gear at the back?
better double check it....
