View Full Version : BC260
repeatcopiers
04-07-2009, 01:12 PM
I have 2 Sharp ARBC260 copiers that have a faint line going vertically on the page every 2 inches. It only happens on black and white, color copy is perfect. I have changed out the fuser, transfer belt, toner/dev cartridge and black drum unit. Any ideas? Thanks, Debi
Nachoman4life
04-07-2009, 02:11 PM
sounds like the toner cart drive gear ngerh1530fcz3, they crack and cart drive stops every time the crack rotates to a certain point, very common
repeatcopiers
04-07-2009, 02:24 PM
Thanks so much.
Nachoman4life
04-07-2009, 08:41 PM
gave you the wrong number its fcz4, even though they seem to be exactly the same gear
repeatcopiers
04-07-2009, 09:43 PM
Precision Roller does carry both gears under 1 part number. Thanks again.
Nachoman4life
04-08-2009, 02:34 AM
no prob had to use one today before responding to your post, you may want to get a few even though they are an updated gear they break frequently, especially if you have a lot of that model. I haven't had to use too many on black, usually on color, but at least if you have smaller arms the black is easy to change. color if you cant squeeze your arm back there you can always come from below in the transfer belt cavity.
