View Full Version : Konica Minolta Di-551
Naveed Shahid
04-07-2009, 09:19 PM
Hello Every One
I have a Minolta Di551 I am facing a problem Sc 29-01
can any one give me solution
thanks for advance
naveed
mo0651
04-07-2009, 10:27 PM
Open front cover, release jam handle on paper transport unit, pull it toward you. look at the toner dropping down on the transfer/sep unit. the sensor for the wire cleaner is under that unit. take out two screws, lift out transfer/sep unit and clean out the pile of toner. put it back together. and you should be set.
mtech
04-07-2009, 11:50 PM
If it was a 21-xx code cleaning the carona might work. What you need to do is pull the drum unit out and clean the whole unit especially behind the drum. You have a Dmax sensor error. Clean the process unit and you should be okay. FYI: check the life of the drum and supplies.
