View Full Version : Sharp M205 L6 Sub10
mthomp
04-09-2009, 03:36 PM
changed LSU and Main board from good M205 still get code shortly after power on
help needed
blackcat4866
04-10-2009, 01:14 AM
Did you replace the mirror motor only, or the laser assembly? In either case I have gotten a few new inoperative Sharp laser units.
Also try replacing the ribbon cable. =^..^=
mthomp
04-10-2009, 03:51 PM
customer LSU works in our test M205 copier
same with main board
why the ribbon cable?
thanks for the reply
blackcat4866
04-11-2009, 02:29 AM
It is very easy to damage the foil thin connections at the ends of the ribbon cable. All it takes is a razor thin crack in one of the conductors. =^..^=
