View Full Version : K7145/IP432 display PRINTER BOARD FAILURE message
kmcopytech
04-10-2009, 06:02 PM
Print controller unit not initialize,
after upgrading the system code via the Compact Flash (CF) procedure.
A few minutes late show PRINTER BOARD FAILURE message!!!!
Need IP432 service manual.
My E-mail:kmcopytech@gmail.com (kmcopytech@gmail.com)
Help me.
Thanks!!!
konisolver
04-10-2009, 07:48 PM
Re-flash the cf card with base code. Don't format the card just copy and paste. If that does not work make sure to remove the hard drive from the print controller. If you are using the cf hd2gb just remove it. It's only purpose is to store fonts.
kmcopytech
04-11-2009, 01:50 AM
When upgrading the system compact flash(CF),
CF card was accidentally formatted in the WINDOWS!!!
Connect the IP-432 with the computer via serial port (DB9 null modem cable) ,
startup hyper terminal on PC so that service port ,
Run Vxformat order to format CF card,
necessary refer the IP432 service manual,
Please provide help!
Thanks!!!
pepper38_cnd
04-11-2009, 07:11 PM
I believe I posted the instructions for one of your other post re an Ip-423 the procedure should be the same. I recommend TeraTermial as the serial interface a little more stable tan HyperTerminal but either will work. anyway check you email.
kmcopytech
04-12-2009, 01:34 PM
pepper38 cnd:
Thank you very much!!!
The problems have been solved!!!
