View Full Version : konica bizhub C500 pro error 34-08
binary6
04-13-2009, 10:56 PM
Does anybody kknow what error code 34-08 is it started with a paper jam
removed the paper jam then this error came up tried resetting the machine nothing.
thanks
binary6
HORSE
04-13-2009, 11:47 PM
34-08 is Fixing roller Paper Seizure abnomality.
Did you reset 25 Dip Sw 3-1 to 0 ??
If its still doing after reset then there is something wrong with the fuser drive.
binary6
04-14-2009, 12:16 AM
Thanks that sounds about right thats right around where the paper was stopping (12x18) next question reset codes i cant pull the fuser drawer out as soon as i turn the machine back on goes straight into error code. sydney huh
well i'm an auslander too born and raised in the bush outback queensland spent most of my time in melb though, as soon as i was old enough to get out of dodge. came over here in 1985.
binary6
04-14-2009, 12:26 AM
HORSE
04-14-2009, 05:37 AM
No Worries!!!
Hold down buttons 2 & 5 and switch the machine on, that will bring you straight into 25 mode.
Go to Dip Sw 3-1 and change from 1 to 0.
Good Luck Mate
binary6
04-14-2009, 05:00 PM
Thanks mate, that worked we are up and running again
thanks for your input
HORSE
04-14-2009, 10:39 PM
No Worries Mate!!
mecanico
04-15-2009, 09:59 PM
Keep on mind that a piece of paper can be allocated in the fixing cleaning unit area! If you do not clear it, there is risk of fire.
Regards.
alecsq01
10-15-2009, 01:52 AM
hello there...i have the same problem
but i already removed the jammed paper but the error code it stills there
i tried the 25 mode but i got lost in the dip sw 3-1...where is that!!!!????? haha...please if you can help me out...i'll appreciate:) cheers!!
binary6
10-15-2009, 06:36 PM
dip switch 3 is a software switch i will have to look at the menu again i willget back to u
binary6
