View Full Version : Konica/Minolta Board Repair
Does anybody know where I can send boards for repair, other than Konica, that is cheap fast and good? Thanks. Any info will help.
brent
04-14-2009, 07:05 PM
I have had good luck with hytec repair
www.hytecrepair.com (http://www.hytecrepair.com)
I hope that link works.
they can send out boards in advance exchange as well
brent
Raymondd
04-14-2009, 07:06 PM
I've used Hytec before (years ago). They were pretty good. Here's a link...
Circuit Board Repair by Hytec Dealer Services, Inc. (http://www.hytecrepair.com/)
Thanks for the info. I used them before but they screwed up with one order and I haven't use them since. I guess I'll try them again.
HB_AL
04-15-2009, 04:01 AM
why not do a certificate in electronics so you then can repair a board for the cost of a cuppa coffee, might take some time but is well worth it
Over the years I have repaired many boards on the old models, now is more complicated because the new boards require more sofisticated equipment to find the components that have failed. I have a degree in electronics, but it is almost impossible to find the components you need, if you were to find them. They also use robots to solder most of these boards. I rather have the guys that have all the equipment do it for me. Thanks anyway.
