View Full Version : Sharp AR-M237 questions....
blacksunshine
04-20-2009, 11:51 PM
what are normal service intervals on one of these, expected lifespan, issues, yadda yadda....
looking at purchasing a used one...
TIA
tmaged
04-21-2009, 12:01 AM
75K on supplies. Feed tires last about the same. Top trays kind of a bitch to change, so we always default the 2nd tray as primary. Good machines. You can stick a $45 USB print server on it & make it a network printer.
mtech
04-21-2009, 12:12 AM
Upper heat roller gets 150K, lower 300K, but kit comes with both. Not a bad machine. Had some developer leak issues early on, but Sharp changed the transfer springs on the right door. (Lengthened them) Seems to have worked. Outside of normal maintenance, just replaced rollers when trays start to jam. Only other thing I can remember is replacing a lot of tray open/close switches. (QSW-B0017QSZZ)
blackcat4866
04-21-2009, 01:55 AM
These machines are a huge improvement over the Panthers & Leopards. As long as you stick to standard 20-28 lb paper stocks you should have very few problems with this model. =^..^=
blacksunshine
04-21-2009, 08:43 PM
supplies meaning ....???
tmaged
04-21-2009, 11:22 PM
Drum, Developer & Cleaning Blade.
Are you an end user or tech ?
blacksunshine
04-22-2009, 12:39 AM
not a tech like most of you but a fix it all electronics tech....IT by trade, copier mechanic when I have to be for the ones I have at the time...telephony tech, computer tech, copier tech, printer tech, alarm tech, network admin, systems admin, domain admin, database admin....aka jack of all trades...
