View Full Version : Sharp MX2300N Call for Service code F2-64
ILRTech
04-21-2009, 04:38 PM
Hi,
Our Sharp MX2300N printer displaying a "Call for Service" error message. The code given is F2-64. Does anyone know what this means?
Thanks,
johnbla
04-21-2009, 08:12 PM
There is a problem with the Bk Toner supply.... check the End Seal was removed on the Cart, if not that, then call a Tech.
ILRTech
04-21-2009, 08:26 PM
Thanks. I'll check it out.
OMD-227
04-21-2009, 10:48 PM
Johnny, you are right......... as always.
Most likely seal tape still on cartridge or possible blocked toner down-pipe.
Yes, call your local tech if checking the cartridge & a restart of the machine fails to correct your issue.
johnbla
04-21-2009, 11:07 PM
ILRTech
04-22-2009, 02:58 PM
So I checked out the bk toner cartridge and there were no obvious problems.
I put the an old, used bk toner cartridge back in and restarted the printer. Once all the codes cleared, I removed the old bk toner and put back the original bk toner I had removed.
That seemed to fix it. The printer is working fine now.
Thanks again for all your suggestions.
