oce bill
04-27-2009, 06:04 PM
Hi All,
I'm having a few problems with the doc feeder on the im3511 machines,
if you place a original in the feeder the original is not picked up,
this only happens intermittently, if it picks up the first original the feeder works fine,The original stopper is moving out of the way, But the take-up tyredoes not feed the original to the feed tyre,You can here the solenoid click in to lift the take-up,
I've change the take-up and feed tyres and cleaned the one-way bearings
there are three machines doing this and they all have under 10K on them
the jam code is SPPD_N
Any suggestions would be greatfully received as the machines are close to going through the nearest window.
