View Full Version : C5500
Biffo
05-21-2009, 09:23 PM
I’ve been left with a problem on a C5500. When I switch it on the machine starts to cycle then come up with C2220. Checked this in the manual and it points to the transfer motor and also the waste toner pipes being blocked.
I have removed and cleaned out the pipes checked the motor using the input output tests but still can’t clear the error.
Any help or advice much appreciated
oscar
09-26-2020, 09:24 PM
Managed to solve?
tsbservice
09-26-2020, 09:38 PM
Managed to solve?
Probably not...mainly because it's DEAD and BURIED for some good 10+ years
Biffo
09-26-2020, 10:54 PM
Managed to solve?
This was along time ago...
From memory and checking the service record, I think it was solved by replacing the encoder and PS75 and PS74 belt 2 and belt 1 driven off m8. This motor drives the belt and waste toner mechanism which was also blocked.
Hope this helps.
Phil B.
09-26-2020, 10:57 PM
Hope this helps.
well I guess 11 years late in the update is better than none at all. :confused::mad:
Synaux
09-27-2020, 07:57 AM
Hope this helps.
My man, you have made 6 posts in total since you joined in 2008 and you promptly respond to this post?
You sir are a legend!
*tinfoil-hat engaged*
