View Full Version : cf8050 j32-08 phantom jam
Eddie
06-01-2009, 08:37 PM
Has anyone experianced a CF8050 creating phantom j32-08 jams.
i replaced the cables, sensor in question, sensor flag and the adu conveyance boarad.
mrwho
06-01-2009, 10:47 PM
Never had anything like it before. Do you have the chance of trying out that fuser on another machine - or a fuser from a working machine on that one - in order to find out if the problem is with the fuser or with the machine itself?
Eddie
06-09-2009, 07:32 PM
This is our only machine, so i cant try another fuser
pspahr
06-09-2009, 08:01 PM
I believe it's caused by a failure of the 3 identical gears in the fusing drive train. All three have a one-way bearing and one fails. Sounds wierd but I swear its one of those 3 gears. If you find they are the cause then order and replace all 3.
If it turns out I'm wrong let me know.
Eddie
06-12-2009, 10:46 PM
thanks, i'll give it a try
kmcopier
06-15-2009, 10:09 PM
first of all try face up output before swapping , if the one way gears are the problems you will notice it directly.
