View Full Version : Konica Minolta 350c
shanorto
06-16-2009, 07:44 PM
Is there any way to temporarily reset a "Replace Image Unit" message on a Konica 350c until the image unit arrives.
newbie
06-16-2009, 08:44 PM
Not that i know of, If the image unit has never been reset and is still putting out a good quality copy than just have the chip reset. And the unit will go for a full term agian before needing replaced.
TheOwl
06-16-2009, 11:59 PM
If you go into 'Security' mode from 'Tech Rep Mode', you can then you can change the 'IU Stop Life' setting.
This will enable the mahine to keep running without the IU being changed. Only problem is that the machine will still display 'Change K Image Unit' and the user will need to press OK on the machine to this prompt so they can copy.
As long as you show the users this, then the above no longer becomes an issue.
nmfaxman
06-17-2009, 02:42 AM
The easiest answer is to keep them in stock.
This is why I don't service Minolta Color.
