View Full Version : C0BA0 Finishing option Elevator drive malfunction
deannasockman
06-22-2009, 10:47 PM
Minolta 3102. Any ideas on what I can check? I have looked at everything on this finisher.
Si@danwood
06-23-2009, 06:09 AM
Had a 3510(fn-117) do this to me only this past friday.Symptoms were that finisher trays initialized,then initialized again then threw up code!Turned out to be the screws holding the middle tray had come loose causing the tray to shift slightly and thus not making the home position sensors near the exit rollers!!!.. Si
deannasockman
06-23-2009, 11:19 AM
Where are the screws located? I'm desperate........ need this job run by Wednesday.
mitchl
06-23-2009, 03:47 PM
Deanna what model finisher is it, the FN-116 or the FN-8? Do the trays move at all when you turn the machine on?
Cantechman
06-23-2009, 05:07 PM
It soulds like a exit tray is not seated properly. Just double check the screws (2 for each tray) that holds the exit trays of the finisher. Make sure nothing is bent, etc. It is usually something minor like that.
deannasockman
06-23-2009, 05:11 PM
Thank you. I will check that asap.
