View Full Version : 7145 Scanning
joneze
06-25-2009, 05:10 PM
Hi,
Its been a long time since i configured one of these machines. Everything is working except scanning it works but each time the user needs to enter the reply address. I have set the machine address within system setting but it does not seem to pick it up for scanning.
Any ideas?
mrwho
06-25-2009, 06:23 PM
This might sound basic, but did you configure the SMTP server?
joneze
06-26-2009, 09:09 AM
Hi,
Yeah i did the scanning does work but you have to put in the reply address manually everytime.
Cheers
mrwho
06-26-2009, 12:43 PM
Did you put the email address in the field reserved for the machine operator?
joneze
06-26-2009, 01:32 PM
Hi,
I have entered the Machine email address, but where do i enter the key operator email address?
mrwho
06-26-2009, 01:44 PM
Try this:
SOLUTION: To configure the email address, perform the following:
1. Using the IP address of the NIC card browse to the utility page.
2. Select Network Setup.
3. Select E-mail Send (SMTP) Configuration.
4. Enter a valid email address in the Key Operator Email Address field.
5. Enter the default "0000" password, or if a Key Operator password is set on the main body, use
the Key Operator password.
6. Select Apply to confirm the setting.
7. Power the machine OFF/ON.
Note: The Enhanced Security mode must be OFF to browse to the NIC.
joneze
06-26-2009, 04:15 PM
Try this:
Thanks for your help. That worked. So is that the only way to set the Key Operator email via the web interface?
Cheers
mrwho
06-26-2009, 04:31 PM
I don't have one of those machines handy, so I'm not sure, but I'd guess not - it's probably buried in one of those options in the operator mode - maybe even under a different name!
Glad it worked!
