View Full Version : Biz420 showing 6001/6701
abilashvk
06-29-2009, 01:52 PM
Hi Everybody,
I'am very new to this biz420.Recently I had to inspect a machine showing C-6001.(As per service manual)I interchanged the CCD unit and PWB-OACB seperatly in another working machine and found both CCD & PWB-OACB are showing C-6701.On refixing original components back, then second machine also displayed C-6701 (which I was able to reset).Do some have such experience then pls., share.Is their any other resetting or shorting can serve the situation?I negetivly suspect possibility of both components going of simultaniously and does the cable replacement needed? Thanks for any help in advance
albasoul06
06-29-2009, 11:40 PM
Reseat connector on OACB # 50GA-93010 and the CCD # 50GA-6261 ..... reseat memory parameter board # 50GA-9111 located on the OACB .... but one or all of these boards may need replacement.
abilashvk
07-06-2009, 02:45 AM
Thanks Albasoul for reply, I checked the OACB board and found ICP3 defective.Can some one tell me where can I get a replacement? I searched for the component in some other main boards(defective,thrashed), but not found any thing similair.Any discription ,rating known for this by someone?:confused:
DCPS
07-07-2009, 12:31 PM
It's a 1.2A SMD fuse. It can also be found on the following boards.
7020/25/30/35/7130/7135 (PRDB) (26NA-9020 or 26TA-9020)
7145 (CB) (40LA-9020)
7222/28/35 (CB) (27LA-9020)
7155/65/7255/7272 (ADUB) (56EA-9040 or 56AA-9040)
