View Full Version : C203-display"License Management Error"
Wasfil
07-07-2009, 06:32 AM
I have aproblem with my C203 Machine, in the monitor Display " License Management Error Occured". The Function of Print & Scan no Problem.But the result of Copy not good, still haved black block in around print area like if we wrong step for the first installation.
thx
Robotech
07-07-2009, 08:31 AM
Hi, as for the grey block you have not followed the setup procedure correctly and need to redo the setup, possibly the date input is incorrect. As for the liscence error, possibly the incorrect serial number was input, you will need to contact your supplier to recieve the correct procedure to correct that issue, its got to do with security.
JSC
07-07-2009, 08:44 AM
to get rid of the gray block you need to re set up the machine or you have a faulty nv ram. as for the license error check the PDF.
Good Luck.
tarzak911
07-07-2009, 03:18 PM
send me ur email addrs i got license agreement correction manual.
thuo
03-29-2011, 09:10 AM
hi
i also require the procedure for going around the license management error.
my email is stkkaira@yahoo.com
thanks in advance
albasoul06
03-29-2011, 01:05 PM
attach me the same
TIA
D Colour
08-24-2011, 05:47 PM
Hello
Would anyone that was emailed the license agreement correction manual be able to forward it onto me?
james@sbmonline.co.uk
Thanks!
B0265
08-25-2011, 08:56 AM
You cand find the procedure in nthe attaced manual.
zibolek
06-13-2012, 02:36 PM
Hi all, could anywane send me the correction manual in my email: zbycholus@gmail.com
Really thank You !
dmitry77
06-18-2013, 07:47 PM
Hi all, could anywane send me the correction manual in my email: dmitry77127@ (dmitry77127@m)gmail.com Really thank You ![/QUOTE]
yulow
10-25-2014, 09:32 PM
i read service manual. i found the procedure to repair the "Software license management error" But i dont have token certification. Where i can find it ? how to obtain it ? Bizhub C203
ncbabak
10-25-2014, 10:01 PM
Hi
I also need for know about the license management error on C451-C650
my email is ncbabak@yahoo.com
Thanks!http://www.copytechnet.com/forums/images/icons/icon11.png
