View Full Version : Bizhub 250 Twain Scanning
DocuSystems
01-11-2007, 08:24 PM
Can't get this to work. Environment is: Bizhub 250 with HDD, Networked with a Fixed IP in a Windows 2003 Domain. The workstation has XP Pro. I've updated the firmware on the Bizhub, and installed the HDD Twain driver, but when I try to acquire a scan, the driver asks for an IP and then tells me that the device is not supported. Anyone out there had any luck with this?
fixerboy
01-15-2007, 04:32 PM
are you trying twain or scan to harddrive if your trying with the pagescope software use the lastest ver.2.0
DocuSystems
01-15-2007, 05:18 PM
Trying to scan using the Twain Driver. It's for a Medical Database/Patient package called AR. This software uses twain to import documents into the patient file.
DocuSystems
01-26-2007, 03:08 PM
The problem was the firmware. Upgraded to the lates (49) and everything started working. Thanks for any posts to this thread!!
gateway.vly@gmail.com
02-21-2008, 05:35 AM
Tell Me How To Update Firmware On Bizhub C250
fixerboy
02-21-2008, 11:25 PM
There is a firmware updater that konica minolta uses to write to the card. A compact flash card 129mb is needed
02-22-2008, 03:41 AM
where i can find the fireware
