View Full Version : CF5001 - yellow developer goes out from dev unit
21043
08-28-2009, 05:09 AM
hello!
in CF5001 yellow developer goes out from dev unit
first i change developer, no effect. then developer go out from unit again and a gear on dev unit was damaged - i change whole unit - no effect, today developer again out of dev. unit and gear damaged again.
i already try to reset settings to default - what can i do with it?
Thank you!
sidneyaus
08-28-2009, 08:21 AM
Bios voltage keeps the devolper in the unit i would look for a bios leak or a break in the connectors
21043
08-28-2009, 08:47 AM
what is a BIOS leak?
connectors are ok.
developer goes out only from one side - where the gears.
by the way, where can i get spare gears?
thank you?
