View Full Version : FS-C5030
LNorris
09-03-2009, 05:35 PM
rebuilt a 5030 with mk. now the Magenta is giving a 0953 error (magenta led), i have swapped drums with the Cyan and Yellow with the same error. i'm leaning towards the ledrly board....but i wanted to check with you guys first to see if you have seen this and what the resolution may have been.
thanks
LNorris
09-03-2009, 09:21 PM
ok, the magenta is showing correctly and no errors. however the print has streaks running thru it, which is one of the things i was fighting before.
i've attached (even tho its in b/w you can see the light streaks).
blackcat4866
09-04-2009, 01:10 AM
You've probably already cleaned the LED heads several times. When you swap the cyan drum unit with the magenta drum unit, does the streak pattern in the patches switch places? I suspect not. I think that its a developing issue.
LNorris
09-04-2009, 01:47 AM
yeah, cleaned the leds. i swapped all 3 color drums and issue remains. i am beginning to think its the ledrly pwb, but not sure...so frustrating...lol
