View Full Version : 3102 Color copier
alonzo
09-09-2009, 07:45 PM
I need help on reasetting the ,replace fuser soon code. Thanks Alonzo
perdana
09-10-2009, 05:21 AM
You need to replace the fuse inside the fusing unit. About 6o ma.
alonzo
09-10-2009, 02:58 PM
I dont meen to sound like a know it all but I know that. Where is the fuse located I took the front cover off and the conector off found no fuse. Help
rasman67
09-10-2009, 03:08 PM
The fuse is located under the bottem cover, it is kind of a pain to get to it good luck
alonzo
09-10-2009, 10:59 PM
Thank you I will take a look is it a normal fuse or a pico fuse? But I do apreaciate the info.
rasman67
09-10-2009, 11:02 PM
it is a pico fuse. you can use the same fuse used to reset di351 Imaging units
alonzo
09-13-2009, 02:13 AM
I have not made it there yet to look for the fuse but I do appreciate the resply Thank You Alozo
alonzo
09-18-2009, 08:08 PM
that took care of the problem a pain to get to like you said but it did the trick thanks
