C250p
  • big jase
    • Jul 2008
    • 136
    C250p
    hello friends
    can anyone help i have a 250p showing cf023 ,i have checked service manual it shows :-
    MsgQue OverFlow
    i have tried reseting machine, alway the code reappears
    If at First you don't succeed remove all evidence of ever trying!
  • ni311
    • May 2008
    • 658
    NVRAM error, try to make a NVRAM reset.
    Konica Minolta Error Codes - Explanations and Solutions
    • PaperCut
      • Sep 2008
      • 21
      Corrupt firmware, failed memory or PWB-MFP board.
      Reflash with current firmware. Or latest version firmware. Perform a Memory Test and replace Memory Module if needed. If the problem persists, replace PWB-MFP
      • big jase
        • Jul 2008
        • 136
        turn out to be customers network ! whenever they sent print it throw up the code, with network lead out mc was fine
        • kmcopier
          PSP
          • Oct 2008
          • 183
          this error os solved with Firmware you see this with P versio without HDD. Install latest firmware and if possible HDD
