View Full Version : Scan problem with Bizhub C200
-ph-
10-09-2009, 03:02 PM
I have a strange problem with some of these machines. If I scan an original through the feeder or from the copyboard in portrait size a4, it will appear always in A4 landscape on my computer screen. I can't find any setting to change this, I tried with different FW releases. latest FW is now G00-30.
I have this problem only with a few of these machines, some other machines are working well.
Any Ideas?
B0265
10-09-2009, 03:35 PM
As far as I know the C200 works in that way. The "rotation TX" function only works for Fax transmission.
emujo
10-09-2009, 03:36 PM
Inherrent design limitation on these older boxes. Change original orientation to landscape, little slower, but will appear correctly at PC. EMujo
-ph-
10-12-2009, 02:52 PM
ok, thanks!
musam
10-14-2009, 10:53 AM
hi copy techs
i need instructions on setting up scan to smb i am using XP PRO.
-ph-
10-14-2009, 02:47 PM
You'll need a "phase 2.0" model of the C200 otherwise scan to SMB is not possible. Check the webinterface through your browser if you can find the scan to smb setting it is a phase 2.0 model.
