View Full Version : Konica bizhub 1050 error code
daveinli
10-13-2009, 07:22 PM
does anyone know what the code SC 23-13 means and how to fix???
thanks
David
xpress
10-13-2009, 07:28 PM
SC23-13 Air separation motor (M10) rotation abnormality.
Since an error is detected when M10 turns ON, turn it OFF. An error is still detected when turn it ON again. Air separation motor (M10) Air motor encoder sensor (PS30) Resetting of the intermediate toner hopper section
I believe they separate paper in the trays. check fans by hand, mabie just got stuck or some paper in them.
arisalonica
11-05-2009, 07:44 PM
If you still have the problem just take a look on the ICP 23 on the printer control board.
brian155
11-06-2009, 09:46 AM
Sc23-13 intermediate toner hopper gears not meshing correctly or locked/blockage can also cause this error
TonerMonkey
11-06-2009, 04:09 PM
It's the sensor below the cover to the right of the optics looking at the top of the machine, it will be covered in toner most likely.
apump
11-09-2009, 03:21 AM
Yes I agree I have ran into the dirty sensor a few times
costel fasola
05-05-2012, 05:47 PM
"It's the sensor below the cover to the right of the optics looking at the top of the machine, it will be covered in toner most likely. " Resolved issues .THANKS
Big Jon
08-18-2015, 09:57 PM
The sensor under the right cover also resolved this code for me. Thank you all for taking the time to post !
vagner
03-23-2017, 03:43 PM
verifi the icp-5 on adu drive board, 9if are blow or opened change him
