View Full Version : c-2855 on Bizhub C203
AEC
11-03-2009, 05:17 PM
Hi all,
Two days ago I changed the unit drum(black) for C203,brand new;after that I receivedd this error C-2558;
Pls reply & many thanx
Alain
Stirton.M
11-04-2009, 06:56 AM
Hi all,
Two days ago I changed the unit drum(black) for C203,brand new;after that I receivedd this error C-2855;
Alain
Check that code.
There is no reference to it on a C203.
AEC
11-04-2009, 07:14 AM
Dear Sir,
The code is c-2558, indeed...the machine counter =60.000 pages...
Stirton.M
11-04-2009, 07:31 AM
That's better...
Imaging unit /K
Toner cartridge /K
Printer control board (PRCB)
1 Reinstall imaging unit — —
2 Reinstall toner cartridge — —
3 Change imaging unit/K — —
4 Change PRCB — —
C2558 Abnormally high toner density detected black TCR sensor
• TC ratio in the developing machine, which is determined by toner replenishing amount control mechanism, is 11 % or more for a given number of times consecutively.
• When the connector of the TCR sensor is disconnected.
Check your TCR level AND setting in tech rep. Verify the TCR level is at or near 7-8% and the TCR Level setting is set to zero.
Print out a dozen 11x17 black halftone at 255 and then do a reset and stabilize. Might also just simply be a bad IU.
AEC
11-05-2009, 01:04 PM
Dear Sir,
Thanx for you reply;indeed was a bad IU;
Many thanx,
Alain
