View Full Version : Kyocera C5200 error codes
drewd
11-13-2009, 10:20 AM
Hi,
I have a C5200 printer that has the following error code.
Call Service
1010:0006592
Anyone know what the problem is?
JustManuals
11-13-2009, 08:49 PM
This Parts & Service manual can now be purchased for $11.77 and downloaded immediately after payment
from The Internet's largest collection of manuals (http://www.justmanuals.com)
Paul@justmanuals.com
LNorris
11-13-2009, 09:21 PM
check to see if tray is lifting or not
1010 Lift motor error
The main motor ready input is not given
for 5 s during the main motor is ON.
Defective bottom
plate elevation
mechanism in the
cassette.
Check to see if the bottom plate can move
smoothly and repair it if any problem is
found.
Defective drive
transmission system
of the lift
motor.
Check if the rollers and gears rotate
smoothly. If not, grease the bushings and
gears. Check for broken gears and replace if
any.
Defective lift motor. Replace the lift motor.
Defective engine
PWB.
Replace the engine PWB (See page
drewd
11-16-2009, 09:44 AM
Thanks.
That worked perfectly
