View Full Version : Capacity over saddle stitcher C353 / FS-609
kanini
11-21-2009, 07:04 AM
Hi! I just can't seem to find out if there's a way to adjust an "auto stop feature" for the saddle stitcher output tray on the finisher FS-609 on a C353/C353P. It makes about 20-25 booklet's and then it automatically stops - even if there isn't any booklet's in the finisher (the user has removed them while printing). After removing the one or two remaining the printer continues printing. Could this be set somewhere, because if the user want's to print let's say 100 booklet's you need to babysit the machine all the time. I've rotated the outlet stopper so the booklet's falls on the floor in a box. Thanks a lot in advance! =)
albasoul06
11-22-2009, 06:16 AM
http://kmbs.konicaminolta.us/salesattachments/mktgadvdocs/bizhub_C353P_Spec_Install_V6.pdf
kanini
11-26-2009, 06:24 AM
Solved the problem by taping up the lever on the saddle stitch output tray that obviously prevented the booklets from exiting the tray into the floor/box, so that maybe one remained and pressed the black switch on the bottom of the tray, and indicated that the tray was full/or activated the counter. Now it collects only about two-three booklets and then they fall out and the counter is reset and allows continous printing.
