View Full Version : error A4200 on kyocera km1635
weslan2002
11-21-2009, 05:44 PM
-I have changed the laser unit,main board,engine pcb,power board,exposure lamp, no changed at all.
-when the machine is powered the error pobs on the screen
- please advise
jewen25
07-22-2010, 02:49 AM
- please advise
you said you change the laser? maybe the laser you change is also deffective?"A4200" is polygon motor problem try another LSU or laser i think thats the problem
aodtech
07-22-2010, 03:25 AM
Do you hear a loud whining noise, aside from the customer at this point? (Rimshot). That's the main indication that the Laser Unit is bad. But normally you'll get just a 4000 code. Try a different Main Charger. Arcing can do some crazy things.
JustManuals
07-22-2010, 06:50 AM
Don't you mean error C4200?
blackcat4866
07-22-2010, 02:35 PM
On Kyocera Mita machines the codes are grouped by type, so that all "4000" series codes are related to the laser, all "6000" series codes relating to the fuser, etc.
The terms are not precise, but the advice is still good . =^..^=
