View Full Version : minolta dialta 351 scanner trembles
javier4065
11-25-2009, 02:46 AM
I have a big problem with this copier, when i want to make copies the scanner begins to tremble, then an abort message appears on the display and the copier starts to initialize again. What Can I do to solve it .
Hansoon
11-25-2009, 05:08 AM
First thing to check would be if the foil, which is sticked along the exposure lamp, doesn't have cracks. If so they can be easily repaired with conductive paint. Some guys even soldered the cracks together which I never did. For me the paint worked fine.
Hans
fixthecopier
11-25-2009, 11:25 AM
the lamp has a short and should be changed
javier4065
11-25-2009, 01:08 PM
But the lamp is lighting,I will check the foil. thanks.
minimerlin
11-25-2009, 07:03 PM
I have a big problem with this copier, when i want to make copies the scanner begins to tremble, then an abort message appears on the display and the copier starts to initialize again. What Can I do to solve it .Maybe the scan motor or its driver pwb has gone down?
javier4065
01-26-2010, 03:47 PM
the problem was the exposure lamp. the foil was broken. thanks everybody for your answers.
Hansoon
01-26-2010, 06:37 PM
Thanks for the feed back.
Hans
