View Full Version : C6500 V60 Firmware
seniortech
12-10-2009, 08:09 PM
Please can someone clarify:
Can you go from V30 C6500 firmware straight to V60 without installing any of the other versions in between; ie does V60 include all the fixes included in any interim versions.
Many Thanks
mr.propper
12-10-2009, 08:50 PM
yes, you can,
all bugfixes included in the last version.
greets
mr.propper
seniortech
12-10-2009, 09:30 PM
Thanks Mr Propper
dljorg
12-24-2009, 02:10 PM
If you really are at v30 (really old) be very careful about the order in which you install the v60 firmware.
To prevent a possibility of the serial communication buss having a problem start with the peripheral FURTHEST to the left of the machine and work back toward the copier. In the copier do I0 Collective first and then C Printer controller last.
Couple of common problems if one of the elements will not accept firmware:
1. CN19 jumper should NOT be used on any peripheral (except the Perfect Binder when putting firmware in it.)
2. If you have an LS large stacker it is common to miss a plug in the wiring harness on install. Machine will work but no firmware will install downstream. Check the install instructions carefully.
Best Regards from the snow in Connecticut!
jma676
06-18-2010, 02:46 PM
Hello iŽneed G00-50 or G00-60 Firmware version and DLBT, for Bizhub C6500.
Thanks.
sbillis
06-18-2010, 10:48 PM
In some machines (I think with V.25? or V.30) you must replace also Image Board with a newer.
must check.
Chromatik
08-29-2010, 07:55 PM
yes, you can,
greets
mr.propper
Hello mr.propper, which is the *bugfixes*?
jma676
08-29-2010, 10:01 PM
wanted to say bug-fixes
RRodgers
08-29-2010, 10:10 PM
Thanks.
And I need to make my car payment. Oh, and a couple of smoking hot twins!
jma676
08-29-2010, 10:13 PM
OK first I send a sausage!!!!!!!!
jma676
08-29-2010, 10:24 PM
Well, I found your special combo,
as willing to pay and I'll send!!
!! is a pleasure doing business with you.
Chromatik
08-31-2010, 04:52 PM
Nice car !!!!!!!! Congratulations
