View Full Version : Biz hub 250
digicor
12-11-2009, 03:16 PM
Anyone have any ideas about grainy copies>?
I have a biz hub 250 , new dv tank, new drum unit, new dv,(yes its 310)
ran f8 and came to ready beautiful. I still have slightly grainy copies print or copy.
thanks
mrwho
12-11-2009, 06:07 PM
Did you reset the PC Life?
• Clear the PC Life counter before removing the IU.
• After clearing the PC Life counter, be sure to turn OFF the main power switch.
digicor
12-12-2009, 04:00 PM
yes thaT eas done also, i do a lot of these machines, and service several, i really never have run into this, usually everyhting ive done to this makes it like new again, i have heard the pwsupply can cause this? any suggestions?
suomi
12-14-2009, 07:33 AM
Transfer roller...
digicor
12-14-2009, 12:03 PM
thanks
OBXtech
12-14-2009, 02:40 PM
I saw the suggestion to replace the transfer roller and you replied "thanks." Does this mean that the transfer roller fixed it? If not, I would look hard at the fuser. Do the copies feel gritty to the touch or is it just visible?
digicor
12-14-2009, 03:10 PM
just visable, i say thanks for the info
I have yet to replace the part
i will post ya or nay abut it
Downunder
12-17-2009, 07:36 AM
try the copper leaf springs on the left of the right-hand door. poor contact.
we are assuming you cleaned glass behind laser flap ( accessed when drum unit out)
Millennium
12-29-2009, 07:51 PM
Had this same issue on a BH350 with over a million copies on it a couple of weeks ago. The copies actually had a grainy feel to them, you could rub the pages together and get a sandpaper sound with them. The problem turned out to be the High Voltage board (located under the black cover under the where the drum unit sits).
Also check to make sure all of the contacts to the drum unit are not bent/deformed. This can cause the same issue.
digicor
12-30-2009, 01:30 PM
thanks for the info, this is good to know.
by the way, i have a BH350c color unit that has a problem with the black and only the black is blurred or what u might call out of focus, the 6 or 9 for example have shadowy inner circle? anything lik ethis happen to you?
minimerlin
12-30-2009, 05:37 PM
Sounds like the usual problem with these units, a dirty led array. Give the black array a good clean (not with the cleaning rod) use IPA or the like, the easiest way is to remove the transfer belt and Image units to get a good go at cleaning.
