View Full Version : bizhub 350 fuser
reddog
12-15-2009, 05:35 PM
About how long does the fuser last on this printer??
EarthKmTech
12-15-2009, 07:10 PM
the life is supposed to be 450k, but depending on how much coverage is on the prints it will be significantly less. They will always fail where the thermistor or thermostat sits against the upper fuser roller, as the toner build up on it destroys the coating and you'll end up with black marks down the copies. Same issue on b250, 350, di 2510, 3510 etc..
reddog
12-15-2009, 07:18 PM
PerthKMTECH
Thank You, I have not dealt with Konica Minolta equipment until a couple days ago.:confused:
minimerlin
12-15-2009, 10:17 PM
You do not have to replace the whole unit , it is reasonably easy to replace the rollers. Also watch out for the red sponge fuser exit rollers, they go off and fall apart.
OBXtech
12-16-2009, 02:50 PM
...it is reasonably easy to replace the rollers...
:p giggle, laugh, giggle :p
minimerlin
12-16-2009, 10:10 PM
Yep I know what you are thinking but when you have done the job as many times as I have......then it just becomes second nature and takes about 45 mins! :o:o Sorry!
fixthecopier
12-16-2009, 10:23 PM
It is a hell of a lot easier than the old di251/351 fusers.
Hansoon
12-17-2009, 06:15 AM
;) :D
Hans
