View Full Version : Bizhub 250 same developer as Bizhub 180?
darastafari
12-28-2009, 02:13 AM
Does anyone know if you can use the same developer in the Bizhub 250 series as the Bizhub 180 series? I know the DI2510 series used the same developer as the DI183, so I'm wondering if that trend continued in the next series of machines.
rocky246
12-28-2009, 04:55 AM
Bizhub 250 uses 8938-451 developer and bizhub 180 uses 8936-488.
FCBM
12-28-2009, 02:10 PM
The Bizhub 180 uses the same DV as the DI-152/183/1811, DI-200/250/251/350/351, DI-2010/2510/3010/3510 but it is not the same as the Bizhub 200/250/350. May just be the weight 200g for the bizhub180 and 300g for the Bizhub 200/250/350.
montana
12-28-2009, 05:27 PM
hi..since one month ago i dealed with the similar problem...i found when i put developer DV110 the machine doesn"t work &gave me c2557 error code..when i installed the right devleoper DV310 the machine accept it
&work right....Ihope it is help...with good luck &happy new year..;)
darastafari
12-28-2009, 06:45 PM
That is what I wanted to try because I have DV110, but not DV310. Anyway, I was able to get a DV310 today and install it along with the drum.
Thanks!
